![]() | Home > Faults & Fixes > Loud pop then suspension standard position only. |
My old red edition did exactly the same after I’d towed the caravan for the first time,It popped a pipe out off the compressor & just needed pushing back in again.mine kept at the standard Ride height.Take the cover off the compressor & check the pipes.
Mick1970 Member Since: 09 Mar 2020 Location: rotherham Posts: 8 ![]() ![]() |
Took it to a dealers today as it was booked in for a new prop fitting. I told him about the suspension issue and asked if he would take a look and give me a quote. Without even looking at the car he pronounced the pump had gone and the bang would be a hole in the tank and that all in it would be £1000. He went on to tell me this was caused by a faulty exhaust valve.
another update now that the suspension has dropped a little when you turn the engine on you can feel the pump running if your hand on it. It runs for around 30 seconds stops for about 5 seconds then runs for another 30 seconds then errors on dash and stops pumping. The pump is not getting hot and its running fast and sounds like its not under load. open to any sugestions what to do next. |
Get a second opinion.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Was this diagnosis from a LR main dealer? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
