![]() | Home > Technical > suspension troubles |
markg103 Member Since: 06 Apr 2020 Location: cambridge Posts: 35 ![]() ![]() ![]() |
Hi thanks for that i didn't realise there was a filter under there i will check it out many thanks
Hi Lazysteve. i see the filter from a diagram before i get under the car is it a filter you clean or just order new filter with pipes
Morning all. well after fixing various problems the car is running perfect well until last night , i drove a mile up the road and heard a loud bang the suspension hasn't dropped but the pipe coming from the Drier had popped out i have pushed it in and feels ok but i was wondering do i have a bad fitting connection or do i have a blockage somewhere that can cause it to build up pressure forcing the pipe out.
lazysteve Member Since: 17 Dec 2011 Location: Bulgaria, Nessebar Posts: 13 ![]() ![]() ![]() |
I had mine changed by the garage as the engine blew up during the time I was having the suspension problems and the body was off so they changed it. It looks like a really difficult place to get to. I had them put a new filter on as I didn't want to have to do it again. |
Thanks Steve, Changed to filter now car just about runs perfect.
Are you talking about the filter inside the vehicle behind the nearside boot trim? Kev
Yes, under the chassis in the back seat area. Never managed to see it until the body was off the car for the engine swap. |
Thanks Steve all finally sort out now
