Home > Technical > suspension troubles
lazysteve
Bulgaria 2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
markg103 wrote:
Hi guys finally got the car running and run a scan, the code it gave is C1131 low air supply can anyone suggest anything other than a compressor before i purchase another one, the compressor runs for a about 5 seconds then the light comes on.
Regards mark
Have you checked the air filter under the back section, feeds the compressor. I did all this, changed compressor, valve blocks, scratched head a lot. Fault code was the same. Changed the filter and problem was fixed.
Post #598723 Fri May 08 2020 7:10pm
markg103
United Kingdom 2006 Range Rover Sport TDV6 HSE Lux Santorini Black
Hi thanks for that i didn't realise there was a filter under there i will check it out many thanks
Regards mark
Post #598724 Fri May 08 2020 7:17pm
markg103
Hi Lazysteve. i see the filter from a diagram before i get under the car is it a filter you clean or just order new filter with pipes
Regards mark
Post #598751 Sat May 09 2020 6:34pm
markg103
Morning all. well after fixing various problems the car is running perfect well until last night , i drove a mile up the road and heard a loud bang the suspension hasn't dropped but the pipe coming from the Drier had popped out i have pushed it in and feels ok but i was wondering do i have a bad fitting connection or do i have a blockage somewhere that can cause it to build up pressure forcing the pipe out.
Regards mark
Post #599297 Tue May 26 2020 8:29am
lazysteve
Regards mark
I had mine changed by the garage as the engine blew up during the time I was having the suspension problems and the body was off so they changed it. It looks like a really difficult place to get to. I had them put a new filter on as I didn't want to have to do it again.
Post #599316 Tue May 26 2020 6:38pm
markg103
Thanks Steve, Changed to filter now car just about runs perfect.
Regards mark
Post #599319 Tue May 26 2020 7:02pm
knwatkins
Are you talking about the filter inside the vehicle behind the nearside boot trim? Kev
Post #599344 Wed May 27 2020 9:57pm
lazysteve
Yes, under the chassis in the back seat area. Never managed to see it until the body was off the car for the engine swap.
Post #599348 Thu May 28 2020 9:21am
markg103
Thanks Steve all finally sort out now
Regards mark
Post #599350 Thu May 28 2020 10:35am
