Home > Maintenance & Modifications > ace pipe leak
Page 1 of 5 12345>
mgrover
ace pipe leak
its the dreaded ace pipe leak Sad But the only saving grace is it seems at a junction? So I assume I can just replace the junction and don't need to drop £1600 quid on it. But I wondered if my reasoning above is right? Also if the cars off and. take the junction off will it just start throwing power steering oil everywhere?
Post #598444 Sun May 03 2020 6:58am
Brit Plumber
Which Union is leaking? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #598446 Sun May 03 2020 8:38am
mgrover
Front of the right tyre
Post #598447 Sun May 03 2020 8:43am
daxmatt
Replaced mine a while back
https://www.rrsport.co.uk/forum/topic54328.html
Post #598451 Sun May 03 2020 10:01am
mgrover
i dont wanna replace the pipes, i mean they are corroded and it will be a ballache when they go. but for now, the only thing thats leaking is the actual junction at the front right of the tyre, does that mean i can just change the junction connector and be on my way? if i whack it open is it going to start spewing a ton of oil everywhere from built up pressure or can it be a 15 min jobo
Post #598453 Sun May 03 2020 10:40am
Brit Plumber
It sounds like you’re referring to the section that changes from steel pipe to rubber pipe. If so, then that’s not available as a separate part from JLR. What you could do is take it to an agricultural supplier and ask them to make up a new section but you may have to remove the part for measurements. 2019 5.0 SC SVA (Current)
Post #598468 Sun May 03 2020 12:57pm
Disco_Mikey
There are 4 pipes behind the front right tyre
Help us out a little Thumbs Up
Post #598474 Sun May 03 2020 2:48pm
daxmatt
When you buy the pipe set,they all come pre clamped,and with the rubber hose,if the pipe has rusted through ,i'd just swap the lot,it will save you in the long run.Are you doing it yourself ?
Post #598479 Sun May 03 2020 3:36pm
mgrover
ah right, it thought there would be connecting sections. right ill will have to be cause £1600 at the independent ain't happening haha
Post #598481 Sun May 03 2020 4:18pm
Brit Plumber
I replaced my front pipes without taking the body off but had to cut the pipes in to half to fit. Another forum member managed it without cutting them in half but I just didn’t have the space to manage it (2012MY). The pipes I think were £260, oil was about £30, high pressure stainless unions were £8, the body fitting I had to replace (I had to cut it off) and I think that was £8 and I then also put a new filter in a few days later (britpart).
Post #598503 Mon May 04 2020 7:34am
mgrover
ta, i'll start scouting the parts, am in Leeds so agricultural stores are hard to come by here Razz i might even dump some some power steering stop leak and top the sucker up on the mean time so the pump doesn't seize.
Post #598505 Mon May 04 2020 8:15am
Brit Plumber
My pipes failed around the rubber body fixing likely due to salt water corrosion under the clamp part. I now wipe the pipes down with oil every so often to try and keep the corrosion down. 2019 5.0 SC SVA (Current)
Post #598516 Mon May 04 2020 10:53am
mgrover
I do wonder how people have such clean pipes since mine literally look like there on deaths door.
Post #598519 Mon May 04 2020 12:16pm
mgrover
if anyones wondering this is the leak
https://photos.app.goo.gl/w9KS5JXqfmjuroHA6
i could probably get away with taking that junction off and just putting connectors on it
Post #598576 Tue May 05 2020 5:41pm
Disco_Mikey
Look at the state of the rest of the pipes. All 4 need replacing
Post #598579 Tue May 05 2020 7:15pm
Page 1 of 5 12345>
