Home > Maintenance & Modifications > ace pipe leak
Page 4 of 5 <12345>
mgrover
ahh fair enough. if you manage it without raising the body lemme know Razz
Post #598939 Thu May 14 2020 5:16pm
Disco_Mikey
2013 car, so no removable outrigger. Chassis and body need separating slightly Thumbs Up
Post #598941 Thu May 14 2020 5:21pm
mgrover
fair enough. i might try make a video for anyone else who tries it themselves. thankfully KFC has reopened near me so I can have either a celebration kfc or a commiseration kfc haha
Post #598943 Thu May 14 2020 5:22pm
daxmatt
you'll need a couple of trolley jacks,will be a whole lot easier,i just jacked the body up one side about 50mm.
Post #598946 Thu May 14 2020 6:17pm
Disco_Mikey
I put stands under the sills, and lower the chassis away from the body Thumbs Up
Post #598950 Thu May 14 2020 8:19pm
Chas9
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Thumbs Up Thumbs Up cheers mate
Post #598959 Fri May 15 2020 3:39am
Chas9
Post #598960 Fri May 15 2020 3:46am
Disco_Mikey
Came out without too much of a fight Thumbs Up
Post #598963 Fri May 15 2020 7:55am
knwatkins
Great news at getting the pipes out Mike.
The rust on that wing though Shocked Kev
Post #598964 Fri May 15 2020 8:05am
Chas9
Bow down nice mate cheers. Am too auld for awe that crawling aboot.
Post #598965 Fri May 15 2020 8:20am
mgrover
So we got most of it done.
It's defo a lift body job but the rear body mount rounded. Only down side is the connection to the power steering pump is Censored so I might just cut the new pipe and old pipe and stick 10mm compression joint
Post #599014 Sat May 16 2020 6:59pm
daxmatt
When you start it up and drive it,keep cheching the fluid level,it wiil need topping up a few times
Post #599015 Sat May 16 2020 7:19pm
mgrover
well its done, valve block is looking somewhat suspect but we'll see. ill need to redo the rear at some point but yah. it seems the spare wheel has to come out for that but means dropping my lpg tank
Post #599037 Sun May 17 2020 5:52pm
knwatkins
Great news, well done Thumbs Up Kev
Post #599040 Sun May 17 2020 6:32pm
mgrover
as a bonus as well no lights cam on the dash either.
Post #599041 Sun May 17 2020 6:32pm
Page 4 of 5 <12345>
