Home > Maintenance & Modifications > ace pipe leak
Page 2 of 5 <12345>
mgrover
yeah though as much basically. dumb question are they just that side of the car. like there isnt any on the other side?
Post #598583 Tue May 05 2020 8:49pm
Brit Plumber
You have 4 pipes on the front right and 2 on the rear right.
Front 4 are
from pump to valve block.
Valve block to reservoir.
And 2 to the front roll bar.
Rear 2 are to the rear roll bar.
If you’re rears are as bad as the front you may want to change both sets. If they aren’t as bad it may be worth doing some deterioration maintenance (I would normally say preventative maintenance but that impossible on these pipes). 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #598585 Tue May 05 2020 8:56pm
Brit Plumber
And this is what the pipe set looks like, different engined vehicles have different pipes so you would need the correct type. The ones here are for the 5.0 but malting list them all.
https://www.ebay.co.uk/itm/Range-Rover-Spo...Swhnlb7T6T
You could also try AF as I think you get a discount through the forum.
It’s also worth getting 2 of the clamps (I think it was 2) as mine just wouldn’t budge and I ended up cutting through the rubber to remove them. 2019 5.0 SC SVA (Current)
Post #598586 Tue May 05 2020 9:02pm
knwatkins
Yeah, they are all a mess and need replacing. Kev
Post #598590 Tue May 05 2020 9:06pm
mgrover
Right cheer Brit Plumber. I'll fix them first then after that I can track the other oil leak down
Post #598591 Tue May 05 2020 9:21pm
mgrover
right pipes ordered. front and back. speaking to the dude he said i dont need to lift the body and he'll send fitting instructions.
weird thing though, last night the front pipes were £300, today they are £340. Ah wells.
I assume I need a filter from BritPart, and how many quarts of cold power steering liquid will I need?
Shall I just order another 2nd hand valve block and be done with it, I don't want the car really stranded on the side of the road since its not on the drive.
bleeding wise, I've seen people say they just run the car, top it up as usual and it'll sort itself out?
Post #598686 Fri May 08 2020 9:24am
knwatkins
It's great news that you're making progress with this. I hope you got your pipes for the lower price!
Make sure you have a 38mm socket when you come to change the filter in the valve block. I had to buy one specially because I didn't have one in my set.
Concerning fluid, I would just buy 5 litres. You then have plenty for future changes, and also you can replace your power steering fluid too. Every time I do an oil change on my car, I drain and refill the power steering and dynamic response fluid reservoirs to keep the fluid fresh.
This is the stuff I use...
https://www.ebay.co.uk/itm/252649100035
Good luck Thumbs Up Kev
Post #598691 Fri May 08 2020 10:22am
mgrover
i didn't but thankfully this is my company car, so ill be able to claim back the VAT
Post #598694 Fri May 08 2020 10:42am
mgrover
quick question Brit Plumber if am buying the couplings, these that you linked to in another post,
https://www.ebay.co.uk/itm/1X-3mm-22mm-Equ...ozqWWKIWnA
I assume am going for the 10mm? Am hoping I'll be able to lift the body but the odds of that might not be great so best have a backup option.
Post #598725 Fri May 08 2020 11:44pm
knwatkins
Apologies, I noticed a typo in my previous post. You need a 38mm socket for the valve block.
Concerning the fittings, I would get good quality fittings from a hydraulic specialist, not Chinese cheapies from eBay. Kev
Post #598731 Sat May 09 2020 9:38am
Disco_Mikey
If your profile is correct, and its an 06 car, the outrigger will unbolt from the chassis, so you won't have to lift the body at all Thumbs Up
Post #598732 Sat May 09 2020 9:44am
Brit Plumber
I think it was the 10mm but I bought mine from a local agricultural and machinery specialist. If I remember correctly, I was pleasantly surprised by the price and got Stainless for something like an extra 20p each and rated to 10 times that of the ACE system. Hopefully you want need them and you can unbolt the out rigger as DM said.
To remove the pipes from the valve block I used a tool like this
https://www.ebay.co.uk/itm/US-Pro-Plastic-...Swj0NUbyln
I put the open end over the flared part of the pipe and levered them out. I believe they can be a nightmare but mine popped out in short order (the car was 7 year old so older could be more difficult). 2019 5.0 SC SVA (Current)
Post #598733 Sat May 09 2020 10:07am
mgrover
id rather raise the body tbh if i can. but the seller seems to think I wouldnt need to. we'll see either way.
to raise the body then I just undo the 1 body screw and start raising the body? or just enough to slide in the new pipes i assume
i already have a set of those trim tools so should hopefully help. i guess id be better off draining the system first. so i dont get power steering fluid all over the place.
Post #598755 Sat May 09 2020 9:17pm
Brit Plumber
I don’t think removing the one bolt will make any difference, there’s 4 or 5? On each side.
Deffo drain the fluid to save it going every where but you’ll still get some running out, you just can’t help it.
When it comes to bleeding the system, I ran the car for a while in sports mode before I got the parts to make my DIY kit. When I did properly bleed the system there was actually very little air left to bleed off anyway. 2019 5.0 SC SVA (Current)
Post #598756 Sat May 09 2020 11:38pm
mgrover
anyone used stuff like ACF50 to try and keep the pipes in good nick?
Post #598758 Sun May 10 2020 10:26am
Page 2 of 5 <12345>
