Home > General > Side steps. |
Ratkat Member Since: 02 Oct 2017 Location: Wolverhampton Posts: 57 |
When I had steps fitted to my 2016 AB they were not threaded, the same make steps, fitted to my 2019 AB by the same fitter and they were threaded.
Sat May 02 2020 7:21pm |
I’m on my 3rd L494 2x my14 & a my15 & ive fitted steps to them all,so I guess I’m lucky they were threaded. Andy.
Sat May 02 2020 7:34pm |
Jeffers Member Since: 27 Apr 2020 Location: South Oxfordshire Posts: 11 |
Now that makes sense, thank you. |
Sat May 02 2020 8:34pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
I’ve been following this thread for a while - I’ve checked all TOPIX fitting instructions for fixed side steps on L494 from 2015 - 19. None advertise the fact that a thread is needed to be made first. I work on a JLR site in BIW & have never known parts or panels being altered to prevent 3rd party intervention. I would assume the same holes are used for genuine as per replica side steps & would therefore create more work for after service which defeats the object. I am confused 16MY Estoril Blue SVR.............
Sat May 02 2020 9:08pm |
That is also true Peachy,if you spec side steps when you buy a sport new I’m sure they don’t factory fit them,they fit them at the dealership when car arrives their,surely all the body’s are made the same.Why make some with the holes threaded & some without. Andy.
Sun May 03 2020 5:48am |
Sun May 03 2020 10:56am |
35 seconds in he mentions the holes have to be tapped and this is a pre 2015 model. He has also made a pig's ear of the cover . |
Sun May 03 2020 10:57am |
Those are totally different steps,the brackets I’ve alway fitted are cast alloy & ive never cut the sill cover.These are the proper brackets that LR also use.
Sun May 03 2020 11:23am |
That's why I mentioned it was pre 2015.
Sun May 03 2020 11:40am |
I’ve fitted steps to 2 my14 & both were threaded. Andy.
Sun May 03 2020 11:44am |
I had them fitted in 2006.
Sun May 03 2020 1:40pm |
Those are definitely not the LR brackets looks like a right diy setup which then asks the question - how safe are these ? Who decided those fasteners could be used in those locations?
Sun May 03 2020 1:44pm |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 |
I’ve just ordered a nice set of fixed side steps and I’m going to fit them today hopefully. I’ve just been under the car for a look and my holes are definitely threaded.. I’m happy because I can’t find a M10 Tap in the garage 🤣 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Thu May 07 2020 12:25pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
Hi with cutting all that trim away wont that cause any issues with water mud etc getting into places where it nots meant to? |
Fri May 08 2020 6:44am |
