![]() | Home > General > Side steps. |
I’ve never removed any covers when I’ve fitted them before 3x,I’ve cut the covers in situ,just watch the fuel lines on the near side ,What do you mean by tapping the holes for the studs,the holes are already there to fit them. Andy.
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
I was wondering that myself?
Jeffers Member Since: 27 Apr 2020 Location: South Oxfordshire Posts: 11 ![]() ![]() |
Hi Andy,
I would have thought they had them to make steps easier to fit.Mines a my15 & the holes were there when I fitted my steps Andy.
Mines also a 2015 and all holes were tapped. Wonder if there’s something weird with powerful steps? Joined the X5 45e club
I wouldn’t have thought they stopped putting the holes there on any model even the newer my18 onwards are basically the same car apart from the shape of a few panels,I had a my18 newer shape in deployable steps bolted the same way as my fixed steps. Andy.
Thanks for replies.
Yes put the bracket up to the plastic trim,Mark with white marker & I cit with a 2” cutter.Are you sure the holes aren’t threaded.?seems weird them not being. Andy.
Wow, I did do it the hard way.
Andy, What cutter did you use? I was thinking of a small cutting wheel on a dremel. Jeff |
That will be fine as it’s only cutting plastic,I used a 2”cutting wheel as that’s what I use at work & it works off air.Just watch the fuel lines on the near side,I unfastened a few clips & pulled the plastic down so I didn’t cut fuel lines. Andy.
Thanks Andy,
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
IIRC on the L320 for example the powerful guys in their fitting guide recommend using a tap to clean up the threads in the existing holes so maybe that's what they're referring to? 2010 TDV8 - current - my first RRS, loving it so far......
That’s true seatown,best thing is spray holes with wd40 then run the bolts in & out to clean them up if you haven’t got a tap.But to be honest the L494 ones are usually ok as the are covered & don’t get much dirt ect on them like the L320’s do. Andy.
