Home > General > Gap iid tool parking aid
quadrant
2005 Range Rover Sport TDV6 HSE Java Black
I was wondering if anyone has completely disabled the parking sensors on 2006 RR Sport please?.
I have a gap iid tool and I've turned off the parking aid but when I put the car into reverse I still get the long beep and flashing led on the button.
There's no sound and no led when going into drive at all but I wanted to completely disable all of the sensors and the flashing led.
The live scan shows a fault on the outer rear sensor, could that be why it can't be completely disabled?
Thanks for any input
Cheers 👍👍👍
Post #597696 Mon Apr 13 2020 11:43am
Why not just replace the sensor and have a fully working system? Or see if the system has a dedicated fuse and pull that. But fixing it rather than fudging it would seem the right option. 2012 SDV6 - it's missing a couple of cylinders
Post #597697 Mon Apr 13 2020 11:56am
quadrant
Thank you for the reply, I will be replacing the faulty sensor as soon as possible to get the system functioning correctly but in the mean time I thought I would be able to completely disable them using my iidtool.
The iidtool has updated the cluster to enable clock display and also updated my gearbox firmware to hopefully help with the dreaded shunt at low speeds, I just wondered if any iidtool gurus could tell me if I'd done the parking aid disable function wrong as I still get the long beep and fleshing led in reverse.
When I scan the ECU's the parking aid is listed as " not present" so I thought I'd done it correctly but I still get the annoying beep an flashing led in reverse.
I might have to live with it until I get round to replacing the sensor unless anyone has any suggestions?
Cheers Thumbs Up
Post #597698 Mon Apr 13 2020 12:18pm
It sounds like you selected rear only fitted.
Could be a fault with the iid software.
Post #597702 Mon Apr 13 2020 2:24pm
Pufftmw
There's a fuse somewhere (on left I think) and removing that disables front/rear sensors and annoying beeps very well Thumbs Up
I did this when I got my car 8 years ago and still haven't bothered to try and fix the sensors, never had any problem parking for sure.
Post #597706 Mon Apr 13 2020 4:47pm
quadrant
I think the fuse removal method might be the way to go in the short term lol...
I've tried all the configuration with iidtool just in case it was something simple but whatever I try the reverse beep and flashing led is consistent, thanks for your help with the fuse idea matey Thumbs Up
Post #597725 Tue Apr 14 2020 6:45am
Could try Fuse 36 5amp behind passengers side glove box.
Post #597726 Tue Apr 14 2020 7:27am
quadrant
Cheers Col, its got to be the fuse removal for the moment - Patrick @ GAP has confirmed that the beep will still be present if there are any faulty sensors even if you disable the parking aid with the iid tool , it is a self test kind of thing that still reports a visible and audible warning if there are any faults on the system.
At least ive got to the bottom of it now Laughing Laughing Thumbs Up
Post #597759 Wed Apr 15 2020 6:59am
Eaters
Cheers Thumbs Up
I believe that GAP are very helpful if you phone them - assuming they are currently available of course... Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #597830 Fri Apr 17 2020 11:22am
