Home > General (L494) > Trickle charge main and ancillary battery?
Dobby
Hello all,
Given I’m not driving so much at the moment, I’ve popped a low amp trickle charger in the terminals under the bonnet to keep the battery going. As I’ve got an MY15.5 I’ve also got that small ancil battery for the auto stop/start gizmo.
I’m wondering if anyone knows if the charger will keep both batteries topped up, or just the main? I find the DashCam runs the ancil battery down anyway, so good to get some charge into it too.
I know the book says to remove the battery for charging, but also that the dealerships charge on those terminals under the bonnet too, and as I’m only trickle charging 2–4 amps I don’t think it’ll cause any problems.
Thanks all,
Dobbs MY15.5 HSE
MY13 110
MY87 90 (ex-mod) (for sale)
Post #597231 Wed Apr 01 2020 10:51pm
PEACHY
I’ve connected my C Tek charger to the under bonnet terminals on both my L494 & left them both for weeks at a time. No issues from either including stop / start Thumbs Up 16MY Estoril Blue SVR.............
Post #597235 Thu Apr 02 2020 9:05am
FrankH
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Charging
Do you set it to AGM mode ? 2015 SDV6 306bhp Dynamic santorini black.
Post #597245 Thu Apr 02 2020 12:09pm
PEACHY
Yes I do - mine has the snowflake emblem which doubles up as AGM Thumbs Up 16MY Estoril Blue SVR.............
Post #597258 Thu Apr 02 2020 2:57pm
Tim in Scotland
Search back and I posted a how to trickle charge the main battery with a £10 solar panel trickle charger on the dash inside the car. I have used this method to try to keep my various modern LR products batteries trickle charged when I was going to sea and leaving the car on my drive up driven for 3-4 months.
Regarding the aux battery for the auto stop/start - last time I called LRA out to get my 2015.5 SDv6 going they advised that the auxy battery only charges when the car is moving and the load on the alternator is low enough, it is handled by the BMS with no way to over ride it so you might have to take that battery out and charge it separately. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #597265 Thu Apr 02 2020 6:38pm
Dobby
Thanks all, and thanks Tim. Yes I found your post on Solar trickle charging, but decided against that idea as I couldn’t find a decent panel with a regulator built into into.
Did whip the ancil battery out and topped it up that way in the end. MY15.5 HSE
MY13 110
Post #597268 Thu Apr 02 2020 7:06pm
Mr R Turner
How do i know if my 2017 RRS HSE has a second battery?
Post #597336 Sat Apr 04 2020 11:36am
Dave-t
It should have stop start, and assuming you do, it will. It’s in the right hand side panel in the boot Joined the X5 45e club
1994 Defender 90 300 tdi
Post #597342 Sat Apr 04 2020 12:46pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
My 2017 has stop start but doesn't have the second battery. There is a capacitor backup system where the second battery used to reside behind the right rear side panel in the luggage area. Not sure when LR changed the system but certainly late 2017 models had done away with the second battery.
Regards Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #597366 Sat Apr 04 2020 9:07pm
Dobby
I think only pre ‘16 have the battery. After that it’s a capacitor. MY15.5 HSE
MY13 110
Post #597405 Sun Apr 05 2020 10:00pm
