![]() | Home > General (L494) > Trickle charge main and ancillary battery? |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
I’ve connected my C Tek charger to the under bonnet terminals on both my L494 & left them both for weeks at a time. No issues from either including stop / start |
FrankH Member Since: 21 Mar 2017 Location: Crawley Posts: 23 ![]() ![]() ![]() |
Do you set it to AGM mode ? 2015 SDV6 306bhp Dynamic santorini black. |
Yes I do - mine has the snowflake emblem which doubles up as AGM |
Search back and I posted a how to trickle charge the main battery with a £10 solar panel trickle charger on the dash inside the car. I have used this method to try to keep my various modern LR products batteries trickle charged when I was going to sea and leaving the car on my drive up driven for 3-4 months.
Dobby Member Since: 02 Jan 2018 Location: East Seaxe Posts: 102 ![]() ![]() |
Thanks all, and thanks Tim. Yes I found your post on Solar trickle charging, but decided against that idea as I couldn’t find a decent panel with a regulator built into into.
Mr R Turner Member Since: 04 Apr 2020 Location: North Devon Posts: 2 ![]() ![]() |
How do i know if my 2017 RRS HSE has a second battery? |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
It should have stop start, and assuming you do, it will. It’s in the right hand side panel in the boot Joined the X5 45e club
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
My 2017 has stop start but doesn't have the second battery. There is a capacitor backup system where the second battery used to reside behind the right rear side panel in the luggage area. Not sure when LR changed the system but certainly late 2017 models had done away with the second battery.
I think only pre ‘16 have the battery. After that it’s a capacitor. MY15.5 HSE MY13 110 MY87 90 (ex-mod) (for sale) |
