Home > General (L494) > Disabling Stop / Start - Solved
mrsammyp
Looks like these guys have figured out how to disable the stop / start feature by removing one cable in the boot space.
Will try it out later but it’s one of my pet hates since moving over from BMW where’s it was disabled with some software.
https://www.rangerovers.net/threads/auto-s...ble.341127
Post #596748 Fri Mar 20 2020 6:54am
scarey
this hack has been available on the fullfatrr.com forum for a long while now..
https://www.fullfatrr.com/forum/topic52063-15.html
Post #596750 Fri Mar 20 2020 8:16am
mrsammyp
Pulled out the cable this morning and can confirm no start / stop! Took 5 mins tops.
Post #596755 Fri Mar 20 2020 9:16am
Dave-t
and the stop/start not available doesn't come up? Joined the X5 45e club
1994 Defender 90 300 tdi
Post #596763 Fri Mar 20 2020 11:51am
mrsammyp
Nope, no errors or anything.
Mine is a MY2017.
Post #596764 Fri Mar 20 2020 11:54am
JamieLC
I’m not sure Mines ever worked!! I’m going to check if the cable has already been pulled tomorrow 2016 Yulong White L494 AB/DYN 3.0SDV6
Post #596865 Sun Mar 22 2020 8:02pm
Dave-t
more likely to be a duff battery Joined the X5 45e club
Post #596873 Mon Mar 23 2020 6:46am
scarey
there are 2 types of stop/start.
one has a small aux battery in the back and the other has a capacitor..
to disable the 'battery' version you disconnect the negative wire.....
to disable the 'capacitor' type , you disconnect the signal wire from the VQM..
Post #596875 Mon Mar 23 2020 9:22am
JamieLC
Does the AUX battery only supply power to the stop/start? 2016 Yulong White L494 AB/DYN 3.0SDV6
Post #596876 Mon Mar 23 2020 9:38am
Dave-t
I believe it just keeps the systems alive whilst stopped, the main one still starts the car. It also seems more intelligent than Disco4 versions and wont stop if the car isn't warmed up and a bundle of other criteria. Joined the X5 45e club
Post #596882 Mon Mar 23 2020 12:11pm
JamieLC
With this being my first Range Rover I wonder if I’m missing something that I’ve never noticed?? Would the car still run fine without the aux battery? Mine seems to be! The cable that disables stop/start is still plugged in but I don’t recall stop/start ever working. Would there be some sort of alert? Embarassed Embarassed 2016 Yulong White L494 AB/DYN 3.0SDV6
Post #596888 Mon Mar 23 2020 5:06pm
Dave-t
Do you have the symbol in the left clock, think it’s A with trike through? What messages come up if you switch it off and on again? The only thing that the stop star5 battery does is keep things alive, it will start, stop and run fine without it. Joined the X5 45e club
Post #596898 Mon Mar 23 2020 7:17pm
JamieLC
Yes when I press the button the light comes on and off on the Center console and also in the left clock get a message saying start/stop on or off. 2016 Yulong White L494 AB/DYN 3.0SDV6
Post #596900 Mon Mar 23 2020 7:47pm
Dave-t
Assuming it starts with no problem, I would hazard a guess you need a new stop start battery, it’s the small one under right hand panel in the boot. If you change it, it won’t work immediately, you will a short run to get up to temperature and charge it. Joined the X5 45e club
Post #596904 Mon Mar 23 2020 8:24pm
JamieLC
So replace the battery, check stop/start works then immediately pull the plug on stop/start because of how annoying it is haha
Thanks for the advice, any chance you have a picture of this battery? 2016 Yulong White L494 AB/DYN 3.0SDV6
Post #596910 Mon Mar 23 2020 9:58pm
