Home > General (L494) > Disabling Stop / Start - Solved |
mrsammyp Member Since: 04 Nov 2019 Location: Kent Posts: 56 |
Looks like these guys have figured out how to disable the stop / start feature by removing one cable in the boot space.
Fri Mar 20 2020 6:54am |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
this hack has been available on the fullfatrr.com forum for a long while now..
Fri Mar 20 2020 8:16am |
Pulled out the cable this morning and can confirm no start / stop! Took 5 mins tops. |
Fri Mar 20 2020 9:16am |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
and the stop/start not available doesn't come up? Joined the X5 45e club
Fri Mar 20 2020 11:51am |
Nope, no errors or anything.
Fri Mar 20 2020 11:54am |
more likely to be a duff battery Joined the X5 45e club
Mon Mar 23 2020 6:46am |
there are 2 types of stop/start.
Mon Mar 23 2020 9:22am |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 |
Does the AUX battery only supply power to the stop/start? 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Mon Mar 23 2020 9:38am |
I believe it just keeps the systems alive whilst stopped, the main one still starts the car. It also seems more intelligent than Disco4 versions and wont stop if the car isn't warmed up and a bundle of other criteria. Joined the X5 45e club
Mon Mar 23 2020 12:11pm |
With this being my first Range Rover I wonder if I’m missing something that I’ve never noticed?? Would the car still run fine without the aux battery? Mine seems to be! The cable that disables stop/start is still plugged in but I don’t recall stop/start ever working. Would there be some sort of alert? 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Mon Mar 23 2020 5:06pm |
Do you have the symbol in the left clock, think it’s A with trike through? What messages come up if you switch it off and on again? The only thing that the stop star5 battery does is keep things alive, it will start, stop and run fine without it. Joined the X5 45e club
Mon Mar 23 2020 7:17pm |
Yes when I press the button the light comes on and off on the Center console and also in the left clock get a message saying start/stop on or off. 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Mon Mar 23 2020 7:47pm |
Assuming it starts with no problem, I would hazard a guess you need a new stop start battery, it’s the small one under right hand panel in the boot. If you change it, it won’t work immediately, you will a short run to get up to temperature and charge it. Joined the X5 45e club
Mon Mar 23 2020 8:24pm |
So replace the battery, check stop/start works then immediately pull the plug on stop/start because of how annoying it is haha
Mon Mar 23 2020 9:58pm |
