Home > General (L494) > Disabling Stop / Start - Solved
Dave-t
Not to hand, but looks like plenty of time to get some.......
If you don’t want it I wouldn’t bother replacing, but I don’t think it’s that bad, although not sure if it’s an mot point??? Joined the X5 45e club
1994 Defender 90 300 tdi
Post #596913 Mon Mar 23 2020 11:29pm
Williamhh
As an aside, does anyone else think the button in the centre console is a bit odd and back to front.
The switch is labelled 'Off' and is lit amber when the system is on. In my way of thinking, I would assume a switch labelled 'Off' and lit amber would mean the system was off?!
Anyone else thought this or is my switch wired upside down?
Post #596954 Tue Mar 24 2020 6:28pm
Dave-t
I think you are over thinking it Rolling with laughter Rolling with laughter Rolling with laughter Joined the X5 45e club
Post #596957 Tue Mar 24 2020 6:33pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Just unplugged the cable near the rear fuse box and no stop start and no error messages after a quick run around the block. As someone said, about a 5 minute job.
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #597148 Mon Mar 30 2020 1:22am
Srg70
Best piece of advice i've had for my RRS, stop start is so annoying. I had to disconnect the earth on the aux battery and worked perfectly. No error messages and stop/start light off. 2015 RRS SDV6 HSE Grey
Post #616327 Tue Aug 03 2021 9:34am
IRBails
Australia
scarey wrote:
there are 2 types of stop/start.
one has a small aux battery in the back and the other has a capacitor..
to disable the 'battery' version you disconnect the negative wire.....
to disable the 'capacitor' type , you disconnect the signal wire from the VQM..
Actually 3 types that I know of. Mine has a large 70 AH battery. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #616335 Tue Aug 03 2021 12:49pm
