Home > Maintenance & Modifications > Mayle Rear pads/discs? |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Anybody used these? Got a metallic rotational noise at low speed and am thinking of a strip and clean of the EPB and may change the discs and pads at the same time. It's from the nearside wheel and can be heard with it off the ground and turned by hand. Plenty of meat on the pads and not seized, I'm hoping it's not the EPB pads, looks like they are a nightmare to change.
Tue Mar 10 2020 11:58am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
does sound like epb shoes or spring come loose |
Tue Mar 10 2020 12:05pm |
Thanks guys, will go for a strip and lubricate first then. If it needs new discs/pads will try the Meyle |
Tue Mar 10 2020 12:41pm |
you may wish to purchase a shoe fitting kit, in case something broke.
Tue Mar 10 2020 6:46pm |
Hi Andy, is that the spring kit like this?
Wed Mar 11 2020 7:33am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
If by any chance your VIN. is after BA701292 you will need this one.
Wed Mar 11 2020 8:35am |
that's the sort of thing |
Wed Mar 11 2020 12:07pm |
Thanks guys, will have a quick look tomorrow and have a see whats what. |
Wed Mar 11 2020 5:20pm |
As said, I suspect it’s the EPB shoes liner breaking down. I had the same problem last year and ended up doing shoes, discs (the loose shoe friction material scored the drum surface) and EBC pads. 2019 5.0 SC SVA (Current)
Thu Mar 12 2020 1:46am |
You may well be right. Once I get the disc off I will be able to see whats what. I was thinking the worse case would be shoes, discs and pads, in which case AF will be getting an order. Fortunately, we have a van for the dogs and I will just have to use that till they arrive.
Thu Mar 12 2020 7:24am |
The shoes nad inside drum only do the parking brake.
Thu Mar 12 2020 12:11pm |
Well, everybody was collectively right. Disc off and it was apparent what the problem was. One of the clips holding the shoes to the backplate had disintegrated and was floating about in the drum. The shoe had moved and has grooved the inner face of the disc and worn the shoe down to the metal. Clearly not the cheap fix then. Off to Advanced factors for discs, pads, shoes, springs and clips.
Thu Mar 12 2020 4:54pm |
Quick update, a parcel from Advanced Factors arrived, all stripped down and new shoes, discs and pads fitted. It looked like the pins and clips were original and the remaining ones were near to failure,but all shiny now.
Tue Mar 17 2020 7:51pm |
