Home > Technical > Oil Leak |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4394 |
It's very easy to snag the seal on the drivers manifold when refitting
Fri Mar 06 2020 8:11pm |
Darren Anthony Member Since: 08 Mar 2019 Location: Birmingham Posts: 30 |
Definitely hoping it's not that.
Sat Mar 07 2020 1:30pm |
As I actually had a bit of time while there was some daylight, I had a look around as best I could in the engine bay. Doesn't seem to be any oil anywhere near the top and cant see any looking down all the possible gaps with a bright torch, so it must be coming from somewhere a bit lower down that can't be seen from above.
Sun Mar 08 2020 8:38pm |
Another thing I just thought of that I hadn’t mentioned. It only leaks with the engine running. Don’t know if that narrows anything down? 2010 RRS 3.0 TDV6 HSE
Mon Mar 09 2020 3:11pm |
Robs_2007_sport_hse Member Since: 12 Mar 2020 Location: Devon Posts: 5 |
I just done a oil leak on mine. it was the oil pump seal to the block and front crank shaft oil seal both humping out oil and throwing it every where...
Sun Mar 15 2020 8:07am |
As much as I was hoping it’s not going to be the inlet manifold, it just seems too much of a coincidence for it not to be. Started leaking almost straight after having it replaced. Was completely fine before that.
Tue Mar 17 2020 9:34am |
Slight update.
Thu Apr 09 2020 9:21am |
Looks like you were right! Took it over to 4 W Motors on Tuesday and he spotted it straight away. So he's got it back in today and is fitting a new manifold gasket for me. 2010 RRS 3.0 TDV6 HSE 1992 Mazda RX7 FD3S |
Thu Apr 16 2020 2:56pm |
