![]() | Home > Maintenance & Modifications > Diesel fuel leak - FBH? |
That's the fuel pump for the fuel burning heater.
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
Thanks Kev.
I'm not sure to be honest Kev. I've never heard of one leaking.
So further investigations made this morning - I'm pretty certain the pump is leaking, it ticks nicely when manual heat is selected on the timed climate screen with a matching steady drip from the black plastic cover end of the pump. No leaks when it's not powered on.
Yeah, I'd go with one from a breakers if you are going to fit it yourself |
