Home > Maintenance & Modifications > Diesel fuel leak - FBH? |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
That's the fuel pump for the fuel burning heater.
Fri Mar 06 2020 6:24pm |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
Thanks Kev.
Fri Mar 06 2020 6:58pm |
I'm not sure to be honest Kev. I've never heard of one leaking.
Fri Mar 06 2020 7:52pm |
So further investigations made this morning - I'm pretty certain the pump is leaking, it ticks nicely when manual heat is selected on the timed climate screen with a matching steady drip from the black plastic cover end of the pump. No leaks when it's not powered on.
Sat Mar 07 2020 1:52pm |
Yeah, I'd go with one from a breakers if you are going to fit it yourself Kev
Sat Mar 07 2020 9:08pm |
