Home > Technical > Brembo Caliper Dust Boots |
AdeParko Member Since: 19 Mar 2010 Location: West Lothian Posts: 60 |
Has anyone ever replaced the dust boots part number LR016685 as seen in item 5 of the link below:
Wed Mar 04 2020 4:47pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
what year car out of interest? |
Wed Mar 04 2020 7:11pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Quite a coincidence, as I have just ordered a couple of sets of the dust boots from Advanced Factors as one of mine has as slight split, may have done it when pads replaced a while back. I did come across that tsb about squealing brakes as well, couldn't find the bit they referred to in the workshop manual though, but it appears to be relatively simple to change them though based on a couple of items I found google as you don't need to disturb the piston/seal to change them, just have the piston out slightly and can lever out old cover and press new one in, I think you may need to at least unbolt caliper from hub for more room though.
Wed Mar 04 2020 8:19pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Wed Mar 04 2020 10:01pm |
Hi, Mikey thanks for reply but can't seem to get the link to work, although it may be just me comes back with The requested URL /gallery/albums/us...282).pdf was not found on this server.
Thu Mar 05 2020 12:49am |
I've uploaded it to this forum too
Thu Mar 05 2020 5:57am |
Brilliant, thank's very much just what I needed, probably help the OP as well I would imagine
Thu Mar 05 2020 6:09am |
Yeah, what Mikey posted was exactly what I was after. A big help. Thank you so much. |
Fri Mar 06 2020 2:13pm |
