![]() | Home > Maintenance & Modifications > 2007 TDV8 RRS Turbo/actuator problems |
Poco Member Since: 16 Jan 2020 Location: Swadlincote, Derbyshire Posts: 12 ![]() ![]() ![]() |
Hi All,
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 ![]() ![]() ![]() |
Poco my turbo is being replaced in Oldbury by a company who do it without removing the body. Best Turbos is the name. Can't vouch for them as I'm in Manchester and it's a warranty job. |
Hi Andy k, Thanks for your info, tried vvt cleaner, just in case but 99% sure it’s the actuator, both turbos running/spooling up ok, but the lh actuator is very lazy to respond, getting electrical signals ok but not moving very much. The link rod has free movement. |
Yes seen their advert and contacted them. Quoted £2000+vat to do both without removing the body. If all else fails !!! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Arh. I see now your profile now says v8
That’s what I was afraid of.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
It's designed to be removed and there is just a process to follow removing and replacing it. It's not the big issue that some seem to think it is. 2012 SDV6 - it's missing a couple of cylinders
I thought as much, may be a little awkward but I’m prepared for that.
possible electrical problems (but you know to look at which connectors you touched)
Got it booked into a local indy next Friday for a firm diagnosis.
Hi Guys, had it into a local Indy, first for a diagnosis then a week later to fit a leaking turbo hose.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Did the TDV8 not have a issue with warping the exhaust manifold and snapping some studs that caused something like that. Just have a vague re-collection of reading something to that effect.
I think so, but it doesn’t have that type of exhaust blow by type of sound, can’t see any tell tail signs of smoke around the manifold but must admit it’s a bit hard to see.
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
I had turbos and brake lines done
