![]() | Home > Maintenance & Modifications > 2007 TDV8 RRS Turbo/actuator problems |
Poco Member Since: 16 Jan 2020 Location: Swadlincote, Derbyshire Posts: 12 ![]() ![]() ![]() |
Well who’d have thought it, really didn’t think it would be an exhaust manifold stud broken, I really stand correcting. Talk about barking up the wrong tree. After stripping out all the heat shields through the n/s wheel arch and removing the top wishbone to get access, I find the tell tail sooty black mark behind the turbo coming from the exhaust manifold / head. Anyone know how to remove the manifold or any ideas how to drill it out and re-tap in situ, or have I got to have the engine out. Relieved it’s not the turbo, but really p!ssed now as its seemingly a bigger job for a 2 bit stud. Cheers Graham |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4430 ![]() ![]() ![]() |
I wouldn't like to try drilling the studs without lifting the body
Hi all, thought I’d update you all on my success.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Well done Poco. Sounds a great fix. Fingers crossed that it holds and lasts... |
Hi all, thought I’d just let you know that 12 months later, the afore mentioned fix is still holding good.
Result! |
OceanCarl Member Since: 12 Jan 2014 Location: Alicante Posts: 11 ![]() ![]() |
