Home > General (L494) > 2018 Steering Wheel Controls For Older RRS - Anyone Done It?
Page 1 of 3 123>
carlos50
Hi all
My loaner is a 2019 and has the newer controls that illuminate, wow they feel so much nicer. I thought I saw a thread about the retrofit that needs an adaptor module to get everything to work, maybe was on the 405 forum, but has anyone done the retrofit on here please? Mines a 2016 SVR with lane assist, heated wheel etc.
Thanks
Carl
Post #593399 Fri Jan 17 2020 9:10am
MattL600
United States 2013 Range Rover Sport Supercharged Santorini Black
Would love to know as well.
I did find this.
Post #593562 Tue Jan 21 2020 7:08am
mrsammyp
Same here.
I’m sure I saw that somebody here has done this, but would love to do it too.
Post #594046 Thu Jan 30 2020 3:26pm
BiffoBear
These guys tried just swapping the control units but had limited success.....
 2016 L494 SDV8 AB
2014 Nissan Leaf Tekna
1989 Toyota MR2 MK1b
Post #595340 Fri Feb 21 2020 8:09pm
May be worth a look
https://www.rrsport.co.uk/forum/post578517.html#578517
Post #595345 Fri Feb 21 2020 10:32pm
mrsammyp
I’ve looked into it, the module / loom you need is about £400 plus the touch controls themselves.
But it can be done.
Post #595346 Fri Feb 21 2020 10:49pm
PEACHY
Forum member Tonywolf has successfully installed the newer switches. I’m awaiting the loom - I have the newer steering wheel & new switch packs the only recycled items will be the airbag & paddles. I’ve been told it can take 2 weeks for the part to arrive but as soon as it’s here it will be fitted the same day. I will take a few pics & a video but I’m not expecting any issues Rolling Eyes Cost has risen to over £700 but never mind Rolling with laughter Rolling with laughter 16MY Estoril Blue SVR.............
Post #595354 Sat Feb 22 2020 4:26am
MattL600
do you have a link to the loom and model numbers of the switch packs??
Post #595355 Sat Feb 22 2020 4:34am
PEACHY
Email the address below & quote your VIN number. - he is based in Romania & will confirm if the loom is compatible with your L494. He responded pretty quick to my emails.
adrian@customretrofit.ro
I believe there may be 2 different finishes on the switch packs - one has a chrome finish the other has a black surround. I went for the chrome to match my current set up & new steering wheel. Apologies I don’t know the numbers for the other colour.
LR092578 & LR092579 are the switch packs.
Good luck Thumbs Up 16MY Estoril Blue SVR.............
Post #595357 Sat Feb 22 2020 6:48am
MattL600
You rock!
Thank you.
Post #595358 Sat Feb 22 2020 6:51am
PEACHY
Matt - check out this on fleabay it’s from your side of the pond Very Happy
Item no - eBay Item No. 153841053272 ( hope link works )
They advertise both colours for the switch packs Whistle
If you look at the pics the loom is from our friend in Romania.
PEACHY Thumbs Up 16MY Estoril Blue SVR.............
Post #595415 Sun Feb 23 2020 12:44am
MattL600
Thanks Peachy!
Ordered.
$1000 USD later. I really think it’ll tie my carbon fiber wheel and leather airbag cover together.
Post #595419 Sun Feb 23 2020 6:36am
Dobby
PEACHY Thumbs Up
Jeez, that’s expensive. The switches are only £76 each. The loom in rather a lot.
https://www.brit-car.co.uk/search.php?query=LR092578
https://www.brit-car.co.uk/search.php?query=LR116681
LR116681 is the new part number for LR092579. MY15.5 HSE
MY13 110
MY87 90 (ex-mod) (for sale)
Post #595420 Sun Feb 23 2020 8:43am
PEACHY
Upgrade done Thumbs Up Bullet Points to consider. ( I learned the hard way ) Rolling with laughter
1. If you have In Control Remote put your Sport into service mode otherwise after disconnecting the battery you will activate the theft alert. Big Cry
2. Make sure you physically open the vehicle.
3. Disconnect the battery - plenty of info on YouTube how to do this. Once disconnected do not push the tailgate closed Big Cry
4. I used a small flat head screwdriver to access the airbag spring - again plenty of videos on YouTube to see how to remove the airbag. When the bottom spring becomes loose the top two will pull out straight. When disconnecting the actual cables from the airbag I used a microfibre towel to keep the front airbag surface from getting marked by surrounding switches. It marks easily & needs manoeuvring to enable cable removal. Keep the removed airbag in a safe place. Big Cry
5. Remove the harness cables from the clock spring & then the steering wheel Torx T50 needed.
6. Swap all components needed to your steering wheel & add the new loom & switch packs.
7. Installation is the opposite from removal.
8. Everything tested & checked with no issues found.
9. You may need to recalibrate your electric windows due to battery disconnection & Put the app back to normal.
FYI - the right switch has 2 extra buttons - Speed limiter which works on mine & lane departure which will be tested tomorrow.These wasn’t on the original switch that was removed.
Pics to be added shortly of finished mod. 16MY Estoril Blue SVR.............
Post #595615 Wed Feb 26 2020 6:48pm
MattL600
All good pointers Peachy!
I remember when I disconnected my battery for when I installed my powerful UK carbon steering wheel and somehow spaced and closed my rear hatch.
That made for reconnecting the battery not so much fun.
Post #595623 Wed Feb 26 2020 8:42pm
Page 1 of 3 123>
