MattL600 wrote:
Just finished the install since we all have so much down time currently.
Took bout an hour and a half.
really puts my wheel to the 100 blackout level that's for sure. I went with the SVR controls as they're all black.
Carbon steering wheel from the Powerful UK gang as well as the aluminum paddle shifters form Velocity AP.
Leather airbag cover as well.
Love it so far..
Hi,
Do you have parts number for both side? I found the ref for chrome, but not for the full black?
Thank you
Wed Sep 09 2020 11:33pm
My order from EuroActive arrived yesterday, will start the fitment later today.
here's hoping my two left thumbs are up to the task --
So finally the awful weather cleared up and I got around to fitting these.
Pretty straightforward process, even for someone as DIY-deficient as me, what with my 3 left thumbs. The most difficult part is actuall getting the screws off the paddles, I left my steering wheel skew when I parked to make it easier to access these.
First step was to disconnect the battery, then have a cuppa while waiting for everything to discharge.
Removing the airbag was very easy, just need to find the spring with a flat screwdriver.
Then, leaving the old controls as they are, I proceeded by replacing each plug from the old loom with ones from the new loom, so that I wouldn't get anything wrong.
Once that was done, I swapped the controls over. I then reconnected the battery (with airbag still removed) and went for a quick drive to test everything.
Once I got back, I disconnected the battery again, taped the new bits of the new loom to the back of the steering wheel, and then reattached the paddles and airbag.
Reconnected the battery, and tested again.
All in all, 2 and a bit hours, with a few tea breaks in between.
Only comment from the Mrs was 'How bling...'
