Home > Technical > Jacks and things |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
the weight of the vehicle is 2.8t from memory and this is split evenly over the two axles, so technically your existing jack and axel stands would be ok to lift one corner.
Fri Dec 20 2019 6:28pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Apart from anything else, 3T jacks tend to have a higher lift than a 2T jack - and the car isn't exactly low to the ground 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Fri Dec 20 2019 6:35pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
You can use 2 axel stands per corner on the drivers side if required.
Fri Dec 20 2019 7:12pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I got a set from sgs engineering,, they do deals with trolley jack and axle stands,, the jack I got was rated at 2,5 T with 3 ton axle stands and the jack has a 530mm lift. Depends how much you want to shell out. 2010 RRS, TDV8
Fri Dec 20 2019 7:58pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Another one for SGS, I have the 3t 465mm lift. It's very heavy so not really suitable for keeping in the car but I have the utmost confidence in it (still use stands as well). I think they have a sale from time to time.
Sat Dec 21 2019 8:55am |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
A pad with a pin to engage in the chassis jacking-points would be good - and re-assuring if that is where you are lifting it. Don't forget the chocks under the floor of the boot. |
Sat Dec 21 2019 11:47am |
Quite a few on the Disco3 forum have trolley jack adaptors and they occasionally come up for sale.
Sat Dec 21 2019 12:52pm |
Hi and welcome
Sat Dec 21 2019 1:09pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
I always remove the two air suspension fuses in the engine bay fusebox before jacking.
Sat Dec 21 2019 1:35pm |
