![]() | Home > General (L494) > All Terrain Tyres - What to do? |
Wjamie Member Since: 03 Dec 2019 Location: Aberdeenshire Posts: 5 ![]() ![]() ![]() |
Hello to everyone, I have just ordered a new RRS SDV6 HSE. I will be looking to take it off road so thought selecting 19" wheels would be a good idea. Given that smaller wheels with higher profile tyres are better for offroad. However it would appear that there are no AT 235/65 r19 tyres available. There are 255/55 r19 AT tyres but this is not a size in the handbook and based on wheel size calculator reduces the ground clearance. Not ideal in that it could cause warranty or insurance issues.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 ![]() ![]() ![]() |
You'll be fine with the 255/55R19 - that was the standard zise on the D4.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 ![]() ![]() ![]() |
I'd go with the 20s and fit 255/55 AT3. It's the same sidewall as the 255/55/19 anyway and the larger diameter overall gives slightly better ground clearance.
or go the whole hog
The Dynamic or the on road / off road pack does add the benefit of the active rear diff. Makes it even better off road. Does add the £s though! |
GregP Member Since: 21 Jul 2017 Location: Gosford Posts: 52 ![]() ![]() |
Goodyear wrangler AT Adventure do a 255/65 R19. but it is a summer tyre. this will give diameter 32". In this part of the world 32" have been shown to fit ok including in the spare hole. This will give 6.5" sidewall. Given that my L494 speedo reads about 3 or 4% high on 31" tyres (so big assumption that it is the same for others) then fitting the 32" tyre will improve speedo accuracy to almost dead on. Not sure on your regulations over there, but over here we can legally go to 7% larger overall diameter. My speculation is that the car was originally designed for 32" diameter, but then no tyres were readily available when it was launched, so they squibbed out and went to 31". I will likely go to 32" diameter on my 20" wheels once my current tyres run out, looking at Pirelli AT Plus in 275/55/R20. MY15.5 SDV6 HSE Dynamic without the H . Yulong White |
RobF Member Since: 11 Oct 2013 Location: Suffolk Posts: 56 ![]() ![]() |
I have 20" wheels with Grabber AT3s and they have got me out of a few slippery situations already this Autumn!
Half Man Half Pie Member Since: 07 Nov 2019 Location: East mids Posts: 7 ![]() ![]() |
the trye, wheel size, numbering, diameter and speedo accuracy etc is all greek to me but I am interested in some better tyres for the winter
All the brake calipers are Brembo, when you spec red you pay for the paint! Should fit, here's a pic of mine (2016 HSE Dynamic). Just back from the car wash....you can see why I need decent tyres for the winter! |
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 ![]() ![]() |
my set of 4 is still for sale.
Thanks to everyone who responded. Lots of good info. |
