![]() | Home > General (L494) > New Windscreen!!! |
I would suggest getting your dealership to do it, even if they farm it out. You should then get an LR branded screen with the right areas for cameras etc and if you have HUD, the correct coating plus you get a 12 months warranty for poor workmanship. They will also hopefully order the right screen for your VIN............. this doesn’t always happen if you go to the other replacement screen companies. Do not be fobbed off by your insurance either who may try to get a cheaper screen fitted to save them money.......... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
RAW Member Since: 05 Apr 2018 Location: Devon Posts: 55 ![]() |
Mine went when 4 weeks old |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 ![]() ![]() |
Mine also needed to be replaced at 4 months old. The new screen, LR branded, was fitted by Kwik Fit with no problem at all. The technician who has bee specifically trained in fitting 'smart' screens knew exactly what needed to be done and was particularly careful about calibration. All went very well. I asked him about the branded screen, he said some were, some were not and he believed there was no difference and come from the same supplier.
I should have said Autoglass and not Kwik Fit. Tim
richamartin Member Since: 16 Dec 2012 Location: Cotswolds Posts: 251 ![]() ![]() |
Thanks everyone... OEM screen being fitted on Friday by Autoglass. Apparently they have all the clips and additional bits already on order.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 920 ![]() ![]() |
Autoglass is fine, although I would not use the mobile ones. Fitting a screen in the pouring rain even though your under a gazebo type canopy to me is a recipe for disaster. Go to one of their units
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
In the factory they can fit a RRS windscreen in under 60 seconds using robots. These robots have some very fancy calibration mechanisms to ensure the screen is fitted perfectly. You'll never get that from a human or two doing a retro fit. So be very demanding who does it and how they do it, i.e. make sure the humans are trained, relaxed.... and sober!
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 ![]() ![]() ![]() |
I have the same to my RRS 2015. A 10 inch long crack in drivers side.
so the replacement is not Pilkington? If the specification and features are the same, will it matter much? Or will you have less features by going with their solution? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Ilard
I feel this would be a case of using National Windscreens would make your life easy, but you should still be able to claim for an OEM windscreen fitted by an alternative supplier, but the claims process will be more laborious. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 542 ![]() |
Hmmmm don’t believe the hype.... my Evoque is pouring water in through the windscreen.... the screen was a genuine screen and has never been changed since fitted at the factory by robots... Speaking to a local windscreen chap he says he has done loads of JLR products where the screen seal has failed... he says it’s always on the top leading edge and getting the screen out is always a bastard because the robots put too much sealant down the sides... It appears that this is exactly the case mine has... ![]() |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1862 ![]() ![]() |
The robots are rubbish!
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
I have just had my L320 done with a none JLR screen,
