Home > General (L494) > DashCam Power
TheGoodWillOut
DashCam Power
I’ve a front & rear dashcam fitted connected to a Tornado Hardwire battery monitor kit which gets it’s power from the fuse box behind the glove box, Unfortunately the dash cams have stopped working because the power connector has worked loose but I’ve no idea which fuse it originally connected to.
Anyone with dash cams fitted care to share what fuse number you get power from? Thanks
Post #590197 Sun Nov 10 2019 12:19pm
TheGoodWillOut
To add, just checked the tornado hardwire battery manual, it requires a permanent 12v live feed, a switched 12v live feed for when ignition is on and of course connection to ground. It’s the permanent 12v which has disconnected but not sure which fuse it was connected to
Post #590198 Sun Nov 10 2019 12:58pm
Tyrefitter
Which RRS have you as I’ve hardwired mine in my15 to a permanent 12v & a switched 12v.I posted in a thread on here somewhere. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #590200 Sun Nov 10 2019 1:37pm
TheGoodWillOut
2017 model
Post #590201 Sun Nov 10 2019 1:56pm
Tyrefitter
Should be same wiring as mine,,check this video out,this is how I wired mine
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #590207 Sun Nov 10 2019 3:37pm
TheGoodWillOut
this is slightly different to mine, the tornado hardwire kits power the cams even when the ignition is off for collision and motion detection when parked, hence why I need permanent 12v. looks like this vid is using switched 12v
I think I've found I can use F30 (sunroof) for permanent live 12v. Using a multi-meter, get 12v with ignition off.
Post #590210 Sun Nov 10 2019 4:26pm
Tyrefitter
Iv3 got a permanent live & ignition live on my Thinkware & wired it like the guy in the video.I can’t remember which fuse I used as I also have a permanent live in case of sudden movement when I’m away from car. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #590214 Sun Nov 10 2019 5:19pm
TheGoodWillOut
Just watched the vid again, he mentions F49 for permanent and F52 for switched. I’ll give that a go
Post #590215 Sun Nov 10 2019 5:28pm
