Home > General (L494) > DashCam Power |
TheGoodWillOut Member Since: 18 Oct 2018 Location: TheNorth Posts: 56 |
To add, just checked the tornado hardwire battery manual, it requires a permanent 12v live feed, a switched 12v live feed for when ignition is on and of course connection to ground. It’s the permanent 12v which has disconnected but not sure which fuse it was connected to |
Sun Nov 10 2019 12:58pm |
Which RRS have you as I’ve hardwired mine in my15 to a permanent 12v & a switched 12v.I posted in a thread on here somewhere. Andy.
Sun Nov 10 2019 1:37pm |
2017 model |
Sun Nov 10 2019 1:56pm |
Should be same wiring as mine,,check this video out,this is how I wired mine
Sun Nov 10 2019 3:37pm |
this is slightly different to mine, the tornado hardwire kits power the cams even when the ignition is off for collision and motion detection when parked, hence why I need permanent 12v. looks like this vid is using switched 12v
Sun Nov 10 2019 4:26pm |
Iv3 got a permanent live & ignition live on my Thinkware & wired it like the guy in the video.I can’t remember which fuse I used as I also have a permanent live in case of sudden movement when I’m away from car. Andy.
Sun Nov 10 2019 5:19pm |
Just watched the vid again, he mentions F49 for permanent and F52 for switched. I’ll give that a go |
Sun Nov 10 2019 5:28pm |
