![]() | Home > General (L494) > DashCam Power |
TheGoodWillOut Member Since: 18 Oct 2018 Location: TheNorth Posts: 56 ![]() ![]() |
To add, just checked the tornado hardwire battery manual, it requires a permanent 12v live feed, a switched 12v live feed for when ignition is on and of course connection to ground. It’s the permanent 12v which has disconnected but not sure which fuse it was connected to |
Which RRS have you as I’ve hardwired mine in my15 to a permanent 12v & a switched 12v.I posted in a thread on here somewhere. Andy.
2017 model |
Should be same wiring as mine,,check this video out,this is how I wired mine
this is slightly different to mine, the tornado hardwire kits power the cams even when the ignition is off for collision and motion detection when parked, hence why I need permanent 12v. looks like this vid is using switched 12v
Iv3 got a permanent live & ignition live on my Thinkware & wired it like the guy in the video.I can’t remember which fuse I used as I also have a permanent live in case of sudden movement when I’m away from car. Andy.
Just watched the vid again, he mentions F49 for permanent and F52 for switched. I’ll give that a go |
