Home > Technical > Gearbox oil contamination
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Hi, my RRS has had what I think is the torque converter shuddering under load for a while, and I'm starting to think about a replacement gearbox. I spoke to a couple of knowledgeable transmission specialists, who say it is probably just the TC, but there could also be some damage to the output shaft, which they can't diagnose until the gearbox is out. Which is fair enough.
Either way, I thought I had read somewhere that there was a possible problem causing gearbox oil contamination, as the engine coolant radiator and gearbox rad are one unit, and someone had found engine coolant in the gearbox oil, causing the TC problem.
I can't find where i read this, and was wondering if I should replace the rad, before getting the gearbox fixed?
Anyone else have experience of this?
Post #588830 Fri Oct 18 2019 12:29pm
almost all cars have the gearbox cooler and rad in the same unit.
It's not a particular common issue on the RRS. Think I heard one occurrence!
You would be better off changing the gearbox oil if you haven't already.
or the gearbox specialist will advise rad replacement if necessary
Post #588838 Fri Oct 18 2019 1:24pm
CornishRob
OK, thanks.
It's had a couple of full flushes in the last 3 years, still the same. Sad
Post #588858 Fri Oct 18 2019 5:12pm
If short of Money you can add dr. Tranny which may stop it.
Other you could try a rebuild place in bristol
Post #588861 Fri Oct 18 2019 6:15pm
CornishRob
Thanks, I did contact them (Bristol Transmissions), as they are not too far. A new one is £3K, which on a car worth £4K maybe £5K makes you think for a while.
I do have a couple of tubes of Dr Tranny, which I may try if it gets worse. (Currently you don't notice it a lot of the time.)
Post #588873 Fri Oct 18 2019 11:23pm
erickwan
Malaysia
Had this last year when the car had done 120,000 miles. It would judder slightly between 1800-2300 rpm. Nothing else would fix it other than a new torque converter.
Post #588919 Sun Oct 20 2019 8:15am
