Home > Technical > Gearbox oil contamination |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
almost all cars have the gearbox cooler and rad in the same unit.
Fri Oct 18 2019 12:24pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
OK, thanks.
Fri Oct 18 2019 4:12pm |
If short of Money you can add dr. Tranny which may stop it.
Fri Oct 18 2019 5:15pm |
Thanks, I did contact them (Bristol Transmissions), as they are not too far. A new one is £3K, which on a car worth £4K maybe £5K makes you think for a while.
Fri Oct 18 2019 10:23pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
Had this last year when the car had done 120,000 miles. It would judder slightly between 1800-2300 rpm. Nothing else would fix it other than a new torque converter. |
Sun Oct 20 2019 7:15am |
