![]() | Home > General > 2013 RR Autobiography |
A common mod is to find a discreet point to insert a switch in to the OBD Port can bus. As for key cloning I keep my key in one of those pouches. 2019 5.0 SC SVA (Current)
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 ![]() ![]() ![]() |
Thanks mate , Got a link to the pouch you use?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
What I have heard of being done is, relocate the OBD plug and fit a dummy plug in it's place and wire it direct to a 12volt feed so if anybody plugs anything into the socket it creates a direct short and fries their equipment. Not sure you would be to popular with a dealer or Indi if car went in for work and you forgot to tell them though. |
It’s the same as this but there are plenty to chose from and plenty of vendors. Amazon, eBay, other online sources etc.
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 ![]() ![]() ![]() |
Ghost autowatch. Real pease of mind since we got it fitted. |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Deactivate keyless entry from the fob...very easy to do...this key no longer transmits signal without press of button and use a faraday pouch and get ghost II immobiliser fitted which requires entry of "pin code" sequence to start the car.. |
Is ghost 2 different from ghost 1 ? I remember seeing somewhere that ghost have a new feature whereby if the door is opened when the car is running e.g. carjacking that the code needs to be put in again before it will move? |
Get a Disklok...to give a visual deterrent in addition to Ghost immobiliser and deactivaying keyless entry on fob and Faraday pouch. |
Sweepinghand Member Since: 09 Nov 2019 Location: Warwickshire Posts: 2 ![]() ![]() |
What he said - I had Ghost on an M3 - though a tad annoying when in a rush - its very very good - your car will go nowhere! |
