Home > General > 2013 RR Autobiography
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Hi Guys.
Looking to pick up a 2013 RR Sport Autobiography on Thursday. I am wondering what alarm systems that people have upgraded to in order to stop key cloning and OBD port access etc etc.
Thanks in a advance
Post #588657 Tue Oct 15 2019 8:50pm
Brit Plumber
A common mod is to find a discreet point to insert a switch in to the OBD Port can bus. As for key cloning I keep my key in one of those pouches. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #588658 Tue Oct 15 2019 8:52pm
McFarTech
Thanks mate , Got a link to the pouch you use?
I would like an alarm system that works along side the oem one. I don't want something I might forget to fit. Viper looks good from what I can see
Post #588660 Tue Oct 15 2019 9:16pm
What I have heard of being done is, relocate the OBD plug and fit a dummy plug in it's place and wire it direct to a 12volt feed so if anybody plugs anything into the socket it creates a direct short and fries their equipment. Not sure you would be to popular with a dealer or Indi if car went in for work and you forgot to tell them though. Rolling with laughter
I have a Blackbox Solution Can Lock, which if I remember correctly fit's in the canbus system which can be fitted basically anywhere in the car out of site if that's any help, have to admit though I never did get around to fitting it.
https://blackbox-solutions.com/shop/category/can-lock
Post #588661 Tue Oct 15 2019 9:17pm
Brit Plumber
It’s the same as this but there are plenty to chose from and plenty of vendors. Amazon, eBay, other online sources etc.
https://www.ebay.co.uk/itm/2-x-Car-Key-Sig...SwZ~hbEAN2 2019 5.0 SC SVA (Current)
Post #588665 Wed Oct 16 2019 6:25am
Gerd1986
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Ghost autowatch. Real pease of mind since we got it fitted.
Post #588678 Wed Oct 16 2019 10:25am
Ash3
Deactivate keyless entry from the fob...very easy to do...this key no longer transmits signal without press of button and use a faraday pouch and get ghost II immobiliser fitted which requires entry of "pin code" sequence to start the car.. Thumbs Up
Post #588682 Wed Oct 16 2019 11:13am
Gerd1986
Is ghost 2 different from ghost 1 ? I remember seeing somewhere that ghost have a new feature whereby if the door is opened when the car is running e.g. carjacking that the code needs to be put in again before it will move?
Post #588685 Wed Oct 16 2019 11:35am
Ash3
Get a Disklok...to give a visual deterrent in addition to Ghost immobiliser and deactivaying keyless entry on fob and Faraday pouch.
Post #589508 Wed Oct 30 2019 8:22pm
Sweepinghand
What he said - I had Ghost on an M3 - though a tad annoying when in a rush - its very very good - your car will go nowhere!
Post #590252 Mon Nov 11 2019 9:37am
