![]() | Home > Technical > oil leak under car |
Hi. No photo showing and the ones in your gallery how the wheel arch. 2012 SDV6 - it's missing a couple of cylinders
Mihai77 Member Since: 07 Oct 2012 Location: Geneva Posts: 33 ![]() ![]() ![]() |
OK, photo uploaded. Forgot to mention that this is shortly after timing belt and brake flexibles were changed. Called LR they said it might some residual. Will take it in ext week for check. Gone:
That looks a bit excessive to me. Even if it's not actively leaking, that they left oil hanging around after work is completed which suggests a shoddy approach. 2012 SDV6 - it's missing a couple of cylinders
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
And if its brake fluid, it will strip off any paint it comes into contact with. |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
Has it got ace ?
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Has the level in the brake fluid reservoir dropped ?
The dealer confirmed that it’s engine oil and it has to do with a seal, following the timing belt change. They say the repair will be covered by the guarantee of the timing belt change. |
Strange. No oil seals should be removed when changing the timing belt |
Do they go near the oil pump tensioner? Another over torqued bolt causing a crack? This could be a lucky escape. 2019 5.0 SC SVA (Current)
Hmm could be. The bolt on the tensioner should only be tightened to 24nm from memory. Kev
In fact they never mentioned a seal just the imperviousness being affected and that they would do it for free. So obviously related to the work they did. Will ask for a clear explanation and report back Gone:
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
Is it clear oil? could also be the transmission cooler, given the location. RRS 3.0 SDV6 HSE Lux
Took the car back. Very unclear explanation saying it was a "joint d'ethancheité" basically an articulation which was not watertight anymore. No cost and no paperwork. Gone:
