Home > Technical > oil leak under car |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Hi. No photo showing and the ones in your gallery how the wheel arch. 2012 SDV6 - it's missing a couple of cylinders
Fri Sep 20 2019 2:09pm |
Mihai77 Member Since: 07 Oct 2012 Location: Geneva Posts: 33 |
OK, photo uploaded. Forgot to mention that this is shortly after timing belt and brake flexibles were changed. Called LR they said it might some residual. Will take it in ext week for check. Gone:
Sat Sep 21 2019 11:17am |
That looks a bit excessive to me. Even if it's not actively leaking, that they left oil hanging around after work is completed which suggests a shoddy approach. 2012 SDV6 - it's missing a couple of cylinders
Sat Sep 21 2019 1:33pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
And if its brake fluid, it will strip off any paint it comes into contact with. |
Sat Sep 21 2019 2:30pm |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 |
Has it got ace ?
Sat Sep 21 2019 7:26pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
Has the level in the brake fluid reservoir dropped ?
Sun Sep 22 2019 4:52pm |
The dealer confirmed that it’s engine oil and it has to do with a seal, following the timing belt change. They say the repair will be covered by the guarantee of the timing belt change. Guess the good news is that I’ll get a free oil change Gone:
Thu Sep 26 2019 8:21pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Strange. No oil seals should be removed when changing the timing belt Kev
Thu Sep 26 2019 8:49pm |
Do they go near the oil pump tensioner? Another over torqued bolt causing a crack? This could be a lucky escape. 2019 5.0 SC SVA (Current)
Thu Sep 26 2019 9:05pm |
Hmm could be. The bolt on the tensioner should only be tightened to 24nm from memory. Kev
Thu Sep 26 2019 9:21pm |
In fact they never mentioned a seal just the imperviousness being affected and that they would do it for free. So obviously related to the work they did. Will ask for a clear explanation and report back Gone:
Fri Sep 27 2019 6:07am |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
Is it clear oil? could also be the transmission cooler, given the location. RRS 3.0 SDV6 HSE Lux
Mon Sep 30 2019 3:59pm |
Took the car back. Very unclear explanation saying it was a "joint d'ethancheité" basically an articulation which was not watertight anymore. No cost and no paperwork. Gone:
Mon Oct 07 2019 1:06pm |
