Home > In Car Electronics > Interior Lights |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
Bulb? power? |
Sun Sep 15 2019 5:37pm |
GerryG Member Since: 07 Jul 2019 Location: Coatbridge Posts: 27 |
Rover 75
Sun Sep 15 2019 6:35pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Could be cjb and expensive |
Sun Sep 15 2019 6:58pm |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
"cjb" ? 2012 SDV6 HSE (technically its hers)
Sun Sep 15 2019 8:05pm |
is it just the case you have switched it off? try holding center button pressed for over 5 sec.
Sun Sep 15 2019 9:06pm |
Which lights do you call puddle lights?
Mon Sep 16 2019 6:51am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
I've always called the one's in the external mirrors the puddle lights. We can now start a debate.
Mon Sep 16 2019 7:04am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
It depends where the puddle is
Mon Sep 16 2019 7:07am |
I can’t remember which way LR call it, the mirror ones only come on when you unlock the car and the front door ones only come on when the car has run and the doors are opened (on mine at least).
Mon Sep 16 2019 8:21am |
The middle switch turns off all interior courtesy lights and the one's in rear doors, has no effect on the front door lights on mine. L/R do call the one's in the door "puddle" lamps and the mirror one's approach lamps.
Mon Sep 16 2019 8:48am |
Hmmm
Tue Sep 17 2019 10:52am |
Because they don't, that's why but there is a mod to get them to work with the doors opening, should be able to find the instructions on the site somewhere but I'm sure someone will point you in the right direction. The one's being referred to are in the bottom of the door or door trim panel.
Tue Sep 17 2019 10:58am |
I wired the rear interior lights up to the boot light with a couple of diodes. The polarity of the bulb holder must also be reversed. As Col said, instructions can be found on this site. Kev
Tue Sep 17 2019 11:53am |
https://www.rrsport.co.uk/forum/topic20566.html Kev
Tue Sep 17 2019 12:07pm |
