Home > In Car Electronics > Interior Lights
GerryG
Scotland
Interior Lights
Hi Giys
Still cant figure out this interior light issue..
The puddle lights work, as do the footwell lights, the fuse is ok, and boot light works, courtesy lights will not come on when the car door is open, but you can press the map lights on.
Ive set the lights to automatic, the middle courtesy button when pressed will turn the puddle lights off, but wont light up, im thinking the unit might be bad as I cant think of anything else,
Anyone came across this before.
Gerry
Post #587017 Sun Sep 15 2019 5:16pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Bulb? power?
Post #587019 Sun Sep 15 2019 5:37pm
GerryG
Scotland
Rover 75
Tried swapping them bulbs, even disconect the battery, still no joy
Post #587022 Sun Sep 15 2019 6:35pm
Could be cjb and expensive
Post #587023 Sun Sep 15 2019 6:58pm
Duc750
"cjb" ? 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #587026 Sun Sep 15 2019 8:05pm
rover75
is it just the case you have switched it off? try holding center button pressed for over 5 sec.
cjb is central junction box behind dash
Post #587028 Sun Sep 15 2019 9:06pm
Brit Plumber
Which lights do you call puddle lights?
To me, puddle lights are the ones in the bottom of the doors. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587036 Mon Sep 16 2019 6:51am
I've always called the one's in the external mirrors the puddle lights. We can now start a debate. Rolling with laughter
Post #587038 Mon Sep 16 2019 7:04am
knwatkins
It depends where the puddle is
...I'll get my coat Kev
Post #587040 Mon Sep 16 2019 7:07am
Brit Plumber
I can’t remember which way LR call it, the mirror ones only come on when you unlock the car and the front door ones only come on when the car has run and the doors are opened (on mine at least).
I was confused by the OPs comment that pressing the middle courtesy light switch turned off the puddle lights. I’ve not tried it but it just seams that function is a little odd/pointless unless he’s referring to the courtesy lights 2019 5.0 SC SVA (Current)
Post #587044 Mon Sep 16 2019 8:21am
The middle switch turns off all interior courtesy lights and the one's in rear doors, has no effect on the front door lights on mine. L/R do call the one's in the door "puddle" lamps and the mirror one's approach lamps.
Post #587046 Mon Sep 16 2019 8:48am
Duc750
Hmmm
finding this quite interesting as I've never got the rear interior lights to function on door open in our car - work fine when manually switched on fronts work with doors no problem at all 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #587100 Tue Sep 17 2019 10:52am
Because they don't, that's why but there is a mod to get them to work with the doors opening, should be able to find the instructions on the site somewhere but I'm sure someone will point you in the right direction. The one's being referred to are in the bottom of the door or door trim panel.
This is one.
http://www3.telus.net/alansweb/RRS/reardoorlights/
Post #587101 Tue Sep 17 2019 10:58am
knwatkins
I wired the rear interior lights up to the boot light with a couple of diodes. The polarity of the bulb holder must also be reversed. As Col said, instructions can be found on this site. Kev
Post #587102 Tue Sep 17 2019 11:53am
knwatkins
https://www.rrsport.co.uk/forum/topic20566.html Kev
Post #587103 Tue Sep 17 2019 12:07pm
