Home > Maintenance & Modifications > Supercharger oil change
geoffsnook
Just ordered my oil now Thumbs Up
Post #553072 Tue Apr 03 2018 5:33pm
didn't even know this was possible!
the workshop manual also makes zero reference to this Shocked --
Post #585467 Sat Aug 17 2019 11:21am
Technical Training
Technical Introduction
NP10
V8JLR: AJ133 5.0
Liter DFI V8 Engine
The supercharger has a fill-for-life internal lubrication
system and is aligned with the secondary accessory drive
belt. The belt drives the supercharger via the crankshaft
at 2.1 engine speed.
Totally different supercharger to the M112 fitted to the 4.2 engine, Eaton say do not change it unless you have a leak or suspect contamination etc.
Still think it would be advisable to change it at some point, bit like the ZF transmission.
Post #585468 Sat Aug 17 2019 11:34am
You can get kits on eBay.
Yeah when you 80K or 100k miles ish good idea to change.
Post #585471 Sat Aug 17 2019 1:00pm
The problem on the 5.0L I would think is actualy getting to the drain/level plug as it's right at the back of the engine and not a lot of room.
Post #585473 Sat Aug 17 2019 1:18pm
Has anyone here done the oil change on the L494 5L v8? --
Post #585501 Sun Aug 18 2019 7:31am
Does anyone know what oil spec is required for the supercharger on an L494?
And what quantity is needed?
thanks --
Post #605515 Tue Oct 13 2020 10:11am
