![]() | Home > Maintenance & Modifications > Supercharger oil change |
jmcvs Member Since: 26 May 2014 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
My jobs for today were front and rear diff oils and the supercharger oil change.
Remove the filler plug which is a bit tight in space, use a syringe with small tube, which is included in the kit, and insert it into the filler plug hole, twist it around until the tube goes further into the hole and draw the oil out, then refill with fresh oil till it spills, I got my kit from Ebay -
USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60 ![]() ![]() ![]() |
Thanks much! '12 RRS SC
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
Did you take any photos while doing it? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
No sorry, thought about it too late when it was done, but the kit comes with instructions |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
Crikey... didn't even know the Supercharger had it's own oil supply so thanks for posting - I'll be doing this asap given mine is coming up to 100k miles! Did you follow some sort of guide to do this? Never read anything about doing this before... |
Heres the link for the kit on Ebay, it comes with instructions to do the job.
Thanks - I'll have to do a bit of research - don't even know where the supercharger is or what it looks like! |
I finally got around to doing this job at the weekend and am so glad I did. The old oil was pretty appalling to be honest, looked like oxtail soup and smelled pretty bad too. For reference my RRS has done 99,400 miles and they recommend replacing the oil every 50,000...
Your oil looks a lot dirtier than what mine was, and the smell is horrid, another good job well done |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
I wonder if the 2010+ 5.0 engines need the same type of maintenance on their superchargers..... |
typhoo12 Member Since: 10 Nov 2016 Location: United Kingdom Posts: 40 ![]() ![]() ![]() |
Does this need to be done when doing an ordinary service such as oils/filters? |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Great pics but...I`m out..no patience for that. Mine`s due a service in 3 weeks (probably get it done next month) so I`ll mention it then |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
No. Just once or twice in the cars life. |
