Home > Wheels & Tyres > Tyre Change / Vehicle Height? |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 |
Sun Aug 11 2019 11:36am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
BJH1959 / Barrie.
Mon Aug 12 2019 7:36am |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 |
In case I ever have to have this done unplanned (eg after a puncture), how does one put it into tight tolerance mode - or does it need a piece of special equipment (and do all tyre places have it)? RRS MY17 SDV6 AB Evoque MY17 TD4 AB |
Mon Aug 12 2019 7:43am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
It's done with a diagnostics tool, for example the GAP IID tool.
Mon Aug 12 2019 7:59am |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
I usually just lock the car down into access mode as you would if you were in a multi storey car park, this just stops things extending when the wheels are off the ground. Obviously if this is wrong someone correct me please! Wouldn’t like to give bumb info.. Current: 2010 RRS 3.6 TDV8 HSE
Mon Aug 12 2019 8:40am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
That would seem to be totally the wrong approach to me, Stu - since the geo changes (dramatically) between ride heights, camber notably, if you set the camber up at Access height then it should be completely wrong at Normal height?
Mon Aug 12 2019 10:19am |
@ aaronjb, sorry I maybe wasn’t clear with what I meant. It was only for the tyre change I lock it down as it were!. Current: 2010 RRS 3.6 TDV8 HSE
Mon Aug 12 2019 10:23am |
Gotcha, that makes much more sense although I thought the idea was to lock it in fully extended mode for tyre changes; no idea why, just what the tyre place insisted I do.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Mon Aug 12 2019 11:41am |
If I jack my car from extended, my jack runs out of reach. If I jack from access it’s well within its travel limit however when I lower the jack, I can’t get it out as the cars stance has now changed and I have to raise the suspension to remove the jack. If your just changing the tyres there’s no need for tight tolerance mode unless you have the alignment done (which you are). When I enquired at my local Hunter place they said they charge extra for plugging into the diag port as it’s not done as standard so I did it myself on the IDD tool. 2019 5.0 SC SVA (Current)
Mon Aug 12 2019 2:13pm |
Thanks everyone for your thoughts and advice.
Mon Aug 12 2019 8:06pm |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
Think I know what's on top of your wish list |
Sat Aug 31 2019 8:08pm |
Top of my wish list would be a 2 post lift.
Mon Sep 02 2019 2:54pm |
I have a scissor lift that the Cobra is currently sitting on .. brilliant bit of kit.
Mon Sep 02 2019 3:03pm |
