![]() | Home > Wheels & Tyres > Tyre Change / Vehicle Height? |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
BJH1959 / Barrie.
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
In case I ever have to have this done unplanned (eg after a puncture), how does one put it into tight tolerance mode - or does it need a piece of special equipment (and do all tyre places have it)? RRS MY17 SDV6 AB Evoque MY17 TD4 AB |
It's done with a diagnostics tool, for example the GAP IID tool.
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 ![]() ![]() ![]() |
I usually just lock the car down into access mode as you would if you were in a multi storey car park, this just stops things extending when the wheels are off the ground. Obviously if this is wrong someone correct me please! Wouldn’t like to give bumb info.. |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
That would seem to be totally the wrong approach to me, Stu - since the geo changes (dramatically) between ride heights, camber notably, if you set the camber up at Access height then it should be completely wrong at Normal height?
@ aaronjb, sorry I maybe wasn’t clear with what I meant. It was only for the tyre change I lock it down as it were!. Current: 2010 RRS 3.6 TDV8 HSE
Gotcha, that makes much more sense |
If I jack my car from extended, my jack runs out of reach. If I jack from access it’s well within its travel limit however when I lower the jack, I can’t get it out as the cars stance has now changed and I have to raise the suspension to remove the jack. If your just changing the tyres there’s no need for tight tolerance mode unless you have the alignment done (which you are). When I enquired at my local Hunter place they said they charge extra for plugging into the diag port as it’s not done as standard so I did it myself on the IDD tool. 2019 5.0 SC SVA (Current)
Thanks everyone for your thoughts and advice.
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Think I know what's on top of your wish list ![]() ![]() ![]() |
Top of my wish list would be a 2 post lift.
I have a scissor lift that the Cobra is currently sitting on .. brilliant bit of kit.
