![]() | Home > General > Wet floor. |
Could be or for me it was the slight lifting of the scuttle panel and the water gets in via the cabin filter. Did the fix and it's been bone dry since. Pull the cabin filter (behind the glove box) and see if it's wet for a starters.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
There`s no wetness above the floor carpet anywhere. I`ll have a look though, just in case |
Bone dry.
Tried on the flat and the passenger side just bubbles and doesn`t come out under the car. Replacing the tube looks a ball ache. I`ve seen videos where people just replace the end piece / nipple using a 12mm push fit air coupling....What do most people do? Steve. |
Well.....I replaced the bottom section of pipe.....what a ball ache....took me 2 poxy hours!!!! At least it`s draining now |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
Hi Steve
Hi mate. Well....the youtube videos make it look simple..not so. In the end...this is what I did.
It will pull out mate....just gotta yank it..once you`ve fed some wire down. I didn`t fancy messing with the fuse box either. Steve. |
Cheers mate
I “ F |
Mart Member Since: 03 Jan 2019 Location: Sheffield Posts: 15 ![]() ![]() |
Hi all
Bad door seal, bad windscreen seal? 2019 5.0 SC SVA (Current)
