Home > General > Wet floor. |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Could be or for me it was the slight lifting of the scuttle panel and the water gets in via the cabin filter. Did the fix and it's been bone dry since. Pull the cabin filter (behind the glove box) and see if it's wet for a starters.
Sat Apr 14 2018 2:18pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
There`s no wetness above the floor carpet anywhere. I`ll have a look though, just in case Steve. |
Sat Apr 14 2018 2:27pm |
Bone dry.
Sat Apr 14 2018 2:32pm |
Tried on the flat and the passenger side just bubbles and doesn`t come out under the car. Replacing the tube looks a ball ache. I`ve seen videos where people just replace the end piece / nipple using a 12mm push fit air coupling....What do most people do? Steve. |
Sat Apr 14 2018 4:10pm |
Well.....I replaced the bottom section of pipe.....what a ball ache....took me 2 poxy hours!!!! At least it`s draining now Steve. |
Mon Apr 30 2018 4:55pm |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 |
Hi Steve
Mon Apr 30 2018 6:53pm |
Hi mate. Well....the youtube videos make it look simple..not so. In the end...this is what I did.
Mon Apr 30 2018 8:59pm |
It will pull out mate....just gotta yank it..once you`ve fed some wire down. I didn`t fancy messing with the fuse box either. Steve. |
Mon Apr 30 2018 9:01pm |
Cheers mate
Tue May 01 2018 6:58am |
I “ F ING” found it officer |
Tue May 01 2018 7:03am |
Steve. |
Tue May 01 2018 10:37am |
Mart Member Since: 03 Jan 2019 Location: Sheffield Posts: 15 |
Hi all
Fri Aug 02 2019 5:39pm |
Bad door seal, bad windscreen seal? 2019 5.0 SC SVA (Current)
Fri Aug 02 2019 7:04pm |
