![]() | Home > In Car Electronics > 2012 RRS DVD Issue (sound but no image) |
Is it original RSE? Does the DVD play from the head unit onto the rear screens? 2019 5.0 SC SVA (Current)
Blade954 Member Since: 30 Jul 2019 Location: Norfolk Posts: 7 ![]() ![]() |
Hi, yes it is. It has a single disc head unit in the dash. |
Ok, is the dvd playing on the rear screens but not on the front? 2019 5.0 SC SVA (Current)
Yes and no, it plays the soundtrack and both front and rear screens show a black screen with the DVD chapter number, just no bloody video! |
Can you get the codes read? It could be a loose coax between the IAM and the FCDIM or it could be your IAM is goosed. 2019 5.0 SC SVA (Current)
I took it to my local stealer and they’ve apparently checked the physical connections. They’ve said that it may need a software update but that if the update doesn’t work properly, it could completely fry my head unit. They’ve quoted over £3000 for a new one! |
Second hand units from breakers are usually between £14 and £200. How much do they want for an update? 2019 5.0 SC SVA (Current)
£300 + VAT! |
I wouldn’t have thought that the need for a software update would cause the unit to stop playing the video on a DVD? |
Agreed, more than likely they hope a software update will overwrite some corrupt data. 2019 5.0 SC SVA (Current)
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
I previously had an issue where when watching the TV I got sound but no picture, I've no idea if the DVD worked or was the same but thought it worth mentioning that the dealer only did a software update and it sorted everything. I was quite surprised as I was expecting a hardware problem. 13MY Range Rover Sport Autobiography SDV6 - mine
