Home > In Car Electronics > 2012 RRS DVD Issue (sound but no image) |
Is it original RSE? Does the DVD play from the head unit onto the rear screens? 2019 5.0 SC SVA (Current)
Tue Jul 30 2019 11:41pm |
Blade954 Member Since: 30 Jul 2019 Location: Norfolk Posts: 7 |
Hi, yes it is. It has a single disc head unit in the dash. |
Wed Jul 31 2019 6:50am |
Ok, is the dvd playing on the rear screens but not on the front? 2019 5.0 SC SVA (Current)
Wed Jul 31 2019 8:56am |
Yes and no, it plays the soundtrack and both front and rear screens show a black screen with the DVD chapter number, just no bloody video! |
Wed Jul 31 2019 11:43am |
Can you get the codes read? It could be a loose coax between the IAM and the FCDIM or it could be your IAM is goosed. 2019 5.0 SC SVA (Current)
Wed Jul 31 2019 2:28pm |
I took it to my local stealer and they’ve apparently checked the physical connections. They’ve said that it may need a software update but that if the update doesn’t work properly, it could completely fry my head unit. They’ve quoted over £3000 for a new one! |
Wed Jul 31 2019 4:50pm |
Second hand units from breakers are usually between £14 and £200. How much do they want for an update? 2019 5.0 SC SVA (Current)
Wed Jul 31 2019 5:30pm |
£300 + VAT! |
Wed Jul 31 2019 5:48pm |
I wouldn’t have thought that the need for a software update would cause the unit to stop playing the video on a DVD? |
Wed Jul 31 2019 5:49pm |
Agreed, more than likely they hope a software update will overwrite some corrupt data. 2019 5.0 SC SVA (Current)
Wed Jul 31 2019 7:37pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
I previously had an issue where when watching the TV I got sound but no picture, I've no idea if the DVD worked or was the same but thought it worth mentioning that the dealer only did a software update and it sorted everything. I was quite surprised as I was expecting a hardware problem. 13MY Range Rover Sport Autobiography SDV6 - mine
Wed Jul 31 2019 9:59pm |
