Home > Faults & Fixes > Strange wheel wobble |
Not a balance issue or a slightly warped or buckled wheel ? |
Tue Jul 23 2019 7:10am |
Swap wheesl back to fronts & vice vera,if that doesn't cure it it sounds like a worn bush or ball joint,or could even be a warped disc,sticking caliper the list goes on but try swapping wheels round first. Andy.
Tue Jul 23 2019 7:26am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Tyre set perhaps? The tyres can develop a slight flat spot when parked and this take a few minutes of driving to "plump out".
Tue Jul 23 2019 7:29am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
Had a similar issue with my previous sport, as suggested turned out to be tyres getting flat spot when car parked for a couple of days, after driving a short distance and got some heat in tyres it disappeared, it was awhile ago but seem to remember they were Goodyear tyres when eventually change to Pirelli no more issues.
Tue Jul 23 2019 7:48am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Had the exact same problem, sticking brake caliper was the issue. Like you are seeing, the vibration was intermittent which ruled out a buckled wheel or wheel balance problem.
Tue Jul 23 2019 8:35am |
