Home > Faults & Fixes > Strange wheel wobble
Cjrob
Looking for any help
I have a wobble through my steering wheel around 50mph, not so strange, what makes this weird is it then stops after 30/60 seconds then drives fine plus, it’s not consistent, one day it’s there the next it’s not.
Removed the front wheels - nothing obviously worn, nothing loose nothing broken
Next step is to rotate the wheels but after that I am at a bit of a loss ? Any ideas
It’s a 2011 S/C with 58k
Post #584336 Tue Jul 23 2019 7:03am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Not a balance issue or a slightly warped or buckled wheel ?
Post #584338 Tue Jul 23 2019 7:10am
Tyrefitter
Swap wheesl back to fronts & vice vera,if that doesn't cure it it sounds like a worn bush or ball joint,or could even be a warped disc,sticking caliper the list goes on but try swapping wheels round first. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #584341 Tue Jul 23 2019 7:26am
Tyre set perhaps? The tyres can develop a slight flat spot when parked and this take a few minutes of driving to "plump out".
That or a lower arm bush getting tired. 2012 SDV6 - it's missing a couple of cylinders
Post #584344 Tue Jul 23 2019 7:29am
Had a similar issue with my previous sport, as suggested turned out to be tyres getting flat spot when car parked for a couple of days, after driving a short distance and got some heat in tyres it disappeared, it was awhile ago but seem to remember they were Goodyear tyres when eventually change to Pirelli no more issues.
Post #584345 Tue Jul 23 2019 7:48am
GodivaNige
Had the exact same problem, sticking brake caliper was the issue. Like you are seeing, the vibration was intermittent which ruled out a buckled wheel or wheel balance problem.
I found it by stopping immediately after the wobble started and feeling for a hot wheel.
Post #584348 Tue Jul 23 2019 8:35am
