Home > My Range Rover Sport > tailgate
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
OK I located the missing fuse.
Actually not all fuse holders are fitted with fuses as you can see from the photo.
 RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #583542 Thu Jul 04 2019 6:37pm
Brit Plumber
You may have misunderstood me a little.
The basic design is the same for Disco, Sport, FFRR, Evoque, Velar, etc. etc. They then wire it for the model it will be fitted to and programme the ECU for that model. Then they put every fuse in for every option “available” on that model. So you may find a gap in a 2013 L320 sport fuse box for “Telephone Interface Module” because the model never had that option but it will be fitted to the 2013 L405 fusebox as it did. The box receives its part number when the BCM inside is programmed. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583548 Thu Jul 04 2019 7:16pm
LG8340
Ah, that makes total sense and reconciles with what’s in the fuse box.
Many thanks again for pointing me in the right direction.
This forum is invaluable. RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #583560 Thu Jul 04 2019 8:36pm
