![]() | Home > General > Headlamp restoration |
I think I read the lenses have a coating which protects it from UV. It’s worth a try though and youve not lost much if they go dull again in a few months. 2019 5.0 SC SVA (Current)
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
A good quality polish will help to keep this from happening again..
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
Wow! Fantastic results!👍
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
I did this on my previous Lotus
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 ![]() ![]() ![]() |
Forgot to mention in the original posting that I also applied a sealant treatment to prevent the yellowing occurring again!
Greyhound Member Since: 03 Oct 2015 Location: Cheshire Posts: 21 ![]() ![]() ![]() |
wd40 does the same thing on a temporary basis , you need to re do it every couple of weeks |
Tried that. for a while ...made no difference whatsoever. |
Sorry should have said I cleaned them with glass cleaner and then scrubbed with bicarbonate and white vinegar washed off with soapy water and then cleaned with WD40
