Home > Maintenance & Modifications > Exhaust Tips Rattling against Rear Vibration Damper
RRSMAC
I've had a mare this morning.
I bought some Exhaust Tips from Ebay that fit well (its the diesel tips, pointing down) however on the nearside, the exhaust tip is rattling against the rear vibration damper. After googling some other tips i see clams such as 'does not rattle against rear vibration damper' so am i right to assume this is a known issue and i will have to cut my losses or is there a modification i could do without removing the rear damper?
Thanks in advance
Post #582402 Fri Jun 14 2019 12:15pm
Brit Plumber
You can try and alter the fit when you tighten the clamp, helped a little with mine but I still ended up holding one pipe with my hands whilst pushing the other away with my feet. That got it spot on. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #582429 Fri Jun 14 2019 10:28pm
[But I still ended up holding one pipe with my hands whilst pushing the other away with my feet. That got it spot on.]
Exactly what I did with mine when had that issue prior to changing bumpers. Thumbs Up
Post #582430 Fri Jun 14 2019 11:12pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I bought some Hawke exhaust tips in 2010 when my TDV8 was new. There was not enough clearance with the right hand balancer (it touched all the time) so they went straight back in the box. I had about 6-7mm clearance between the balancer and the exhaust.
Post #582432 Sat Jun 15 2019 2:00am
SRE
Spain
I fitted a set of tail pipe trims to a 2008 Sport I use to own. however I did not want the exhaust gasses exiting from underneath the trim as I thought it looked Censored
I bought a set from https://www.adamesh.co.uk/. These were designed to fit on a downturned exhaust with the gasses exiting from the rear. However I had to cur a couple of inches/50mm off the end of the tail pipes as I did not want the exhaust hanging too low.
Look at this thread as it has a couple of photos that mey be of interest to you
https://www.rrsport.co.uk/forum/topic38533...haust+tips In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #582440 Sat Jun 15 2019 8:11am
Eaters
I had exactly the same problem with my exhaust tips from eBay. The left hand one fouled the resonating damper. In the end I fitted them with the nearside one just very slightly off the horizontal plane and mirroring the slant the other way on the offside one. Of course I can see it and its annoying - but to the casual observer I believe it looks acceptable.
These were the ones I bought - https://www.ebay.co.uk/itm/322053837575
Not the best of photos but you get the idea - perhaps Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #582547 Sun Jun 16 2019 4:20pm
03184
Spain 2006 Range Rover Sport TDV6 HSE Santorini Black
I think this is a common problem, I bought a pair from powerfuluk and ended up by physically (using foot) pushing it until it stopped rattling. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
RRS 2008 3.6 V8 SILVER/GREY (WIFES XMAS PRESENT)
Post #582551 Sun Jun 16 2019 5:25pm
